Access-policy - Can you return a "Filter-id" (Group policy name) on access-reject + guest ?
thomasthomsen
Behind the subject is the thought: If I return a group policy (filter-id) in the access-reject message from my radius server will the switch honor this, and apply the GP to the client ?
The thought is to apply a GP, with additional ACLs, to clients being placed in the guest network for an access-policy.
/Thomas
5 Replies 5
Ryan_Miles
Meraki Employee All-Star
Reject or accept? On accept yes it can apply a GP by using filter-ID https://documentation.meraki.com/MS/Access_Control/Meraki_MS_Group_Policy_Access_Control_Lists#Confi...
thomasthomsen
So the answer is no. It can only apply GP on accept.
It does not make any sense but ok.
GreenMan
Meraki Alumni (Retired)
If an access-reject is sent, the switch won't permit access, so I'm not sure how applying a group policy would help?
thomasthomsen
Well the though was that when you utilize Guest VLAN, then the client would be put into that VLAN on an access-reject. And I would just like to return some more config to that Guest access.
https://documentation.meraki.com/@api/deki/files/3974/MS_802.1X_auth_flow_chart.png?revision=1&size=...
