Search instead for
SNMP: Ports schecking anomaly on MX68
Hello everyone Smiley Happy !
I have a question about snmpwalk to meraki device MX68.
I would like to check interface traffic, through my ports, however, these information with snmpwalk are different from that I have in the Meraki dashboard.
In the Meraki dashboard, as you can see below, we  have the port 1 and 11 connected and up.
(Port 1 and 11 are connected and we traffic on these interfaces.)
However, the feedback on the snmpwalk show us the "OperStatus" 1 and 11 as down whereas they are up on the dashboard.
IF-MIB::ifOperStatus.1 = INTEGER: down(2)
According to cisco MIB, ifOperStatus is the current operational state of the interface. If ifAdminStatus is down(2) then ifOperStatus should be down(2).
OID
1.3.6.1.2.1.2.2.1.8
Module
IF-MIB (CISCO)
Nom
ifOperStatus
Acces
readonly
Status
current
Description
The current operational state of the interface. The testing(3) state indicates that no operational packets can be passed. If ifAdminStatus is down(2) then ifOperStatus should be down(2). If ifAdminStatus is changed to up(1) then ifOperStatus should change to up(1) if the interface is ready to transmit and receive network traffic; it should change to dormant(5) if the interface is waiting for external actions (such as a serial line waiting for an incoming connection); it should remain in the down(2) state if and only if there is a fault that prevents it from going to the up(1) state; it should remain in the notPresent(6) state if the interface has missing (typically, hardware) components.
Syntaxe
Enumeration (1-up, 2-down, 3-testing, 4-unknown, 5-dormant, 6-notPresent, 7-lowerLayerDown)
However, in my snmpwalk my ifAdminStatus is up but my ifOperStatus is down.
snmpwalk -v 3 -u 'XXX' -x des -X 'XXX' -A 'XXX' -a sha -l authpriv  AA.BB.CC.DD
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifAdminStatus.2 = INTEGER: up(1)
IF-MIB::ifAdminStatus.3 = INTEGER: up(1)
IF-MIB::ifAdminStatus.4 = INTEGER: up(1)
IF-MIB::ifAdminStatus.5 = INTEGER: up(1)
IF-MIB::ifAdminStatus.6 = INTEGER: up(1)
IF-MIB::ifAdminStatus.7 = INTEGER: up(1)
IF-MIB::ifAdminStatus.8 = INTEGER: up(1)
IF-MIB::ifAdminStatus.9 = INTEGER: up(1)
IF-MIB::ifAdminStatus.10 = INTEGER: up(1)
IF-MIB::ifAdminStatus.11 = INTEGER: up(1)
IF-MIB::ifAdminStatus.12 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: down(2)
IF-MIB::ifOperStatus.3 = INTEGER: down(2)
IF-MIB::ifOperStatus.4 = INTEGER: down(2)
IF-MIB::ifOperStatus.5 = INTEGER: down(2)
IF-MIB::ifOperStatus.6 = INTEGER: down(2)
IF-MIB::ifOperStatus.7 = INTEGER: down(2)
IF-MIB::ifOperStatus.8 = INTEGER: down(2)
IF-MIB::ifOperStatus.9 = INTEGER: down(2)
IF-MIB::ifOperStatus.10 = INTEGER: up(1)
IF-MIB::ifOperStatus.11 = INTEGER: down(2)
IF-MIB::ifOperStatus.12 = INTEGER: down(2)
Moreover, we can some traffic through these interfaces:
IF-MIB::ifInOctets.1 = Counter32: 4267233788
IF-MIB::ifInOctets.2 = Counter32: 0
IF-MIB::ifInOctets.3 = Counter32: 0
IF-MIB::ifInOctets.4 = Counter32: 0
IF-MIB::ifInOctets.5 = Counter32: 0
IF-MIB::ifInOctets.6 = Counter32: 0
IF-MIB::ifInOctets.7 = Counter32: 0
IF-MIB::ifInOctets.8 = Counter32: 0
IF-MIB::ifInOctets.9 = Counter32: 952818
IF-MIB::ifInOctets.10 = Counter32: 0
IF-MIB::ifInOctets.11 = Counter32: 3309773612
IF-MIB::ifInOctets.12 = Counter32: 0
IF-MIB::ifInUcastPkts.1 = Counter32: 316592390
IF-MIB::ifInUcastPkts.2 = Counter32: 0
IF-MIB::ifInUcastPkts.3 = Counter32: 0
IF-MIB::ifInUcastPkts.4 = Counter32: 0
IF-MIB::ifInUcastPkts.5 = Counter32: 0
IF-MIB::ifInUcastPkts.6 = Counter32: 0
IF-MIB::ifInUcastPkts.7 = Counter32: 0
IF-MIB::ifInUcastPkts.8 = Counter32: 0
IF-MIB::ifInUcastPkts.9 = Counter32: 2829
IF-MIB::ifInUcastPkts.10 = Counter32: 0
IF-MIB::ifInUcastPkts.11 = Counter32: 390020574
IF-MIB::ifInUcastPkts.12 = Counter32: 0
IF-MIB::ifInNUcastPkts.1 = Counter32: 0
IF-MIB::ifInNUcastPkts.2 = Counter32: 0
IF-MIB::ifInNUcastPkts.3 = Counter32: 0
IF-MIB::ifInNUcastPkts.4 = Counter32: 0
IF-MIB::ifInNUcastPkts.5 = Counter32: 0
IF-MIB::ifInNUcastPkts.6 = Counter32: 0
IF-MIB::ifInNUcastPkts.7 = Counter32: 0
IF-MIB::ifInNUcastPkts.8 = Counter32: 0
IF-MIB::ifInNUcastPkts.9 = Counter32: 0
IF-MIB::ifInNUcastPkts.10 = Counter32: 0
IF-MIB::ifInNUcastPkts.11 = Counter32: 0
IF-MIB::ifInNUcastPkts.12 = Counter32:
Do you know why we have this please?
 Regards,
NicoSnmp
1 REPLY
Re: SNMP: Ports schecking anomaly on MX68
I don't have an MX68 to check on handy, but my MX64 on my desk reports correctly:
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: up(1)
IF-MIB::ifOperStatus.5 = INTEGER: up(1)
IF-MIB::ifName.1 = STRING: wan1
IF-MIB::ifName.2 = STRING: lan1
IF-MIB::ifName.3 = STRING: lan2
IF-MIB::ifName.4 = STRING: lan3
IF-MIB::ifName.5 = STRING: lan4
I would call support and open a case. What you're describing sounds like a bug to me.
