Search instead for
Azure Virtual WAN
Just browsing
Azure Virtual WAN
any roadmap to support azure virtual wan?
https://docs.microsoft.com/en-us/azure/virtual-wan/virtual-wan-locations-partners
Connectivity through partners
You can check the links in this section for more information about services offered by partners. If your branch device partner is not listed in the section below, have your branch device provider contact us. They can contact us by sending an email to azurevirtualwan@microsoft.com.
The following partners are slated on our roadmap for the near future: Arista, F5 Networks, Fortinet, Silver-Peak, Velocloud, Versa, Nuage Nokia.
2 REPLIES 2
Re: Azure Virtual WAN
With Meraki already have a vMX for Azure - what would be the benefit of doing this?
Just browsing
@PhilipDAth haven't setup any VPN to Azure yet, but maybe cost or management. at the very least its another option. It supports standard IPSEC, but it seems like it can be a one button setup with integration to the Meraki API.
I'm assuming that part of not doing this is to push the vMX.
