Wall Mount Arm For MV72 Series Bolt Hole Dimensions
degarris
Hi MV72 Experts,
We haven't been able to get the specs on the 4 bolt holes on the MV72 wall mount arm, the ones that mount on the wall or a bracket, does anyone have those ?
Update on Bolt hole measurements, TAC engineer Jaspreet Singh was able to provide this information. Wall Arm Mount Measurements Bolt Holes Close Up.JPGWall Arm Mount Measurements Bolt Holes.JPG
3 REPLIES 3
Inderdeep
@degarris : I dont think you will get the info on 4 bolt holes. But the other specs are Wall bracket 160.0mm L × 104.0mm W × 286.0mm D
https://meraki.cisco.com/product/security-cameras/security-cameras-accessories/security-cameras-acce...
Regards/Inder
www.thenetworkdna.com
Aidehuazi
I’ll check in the morning if someone hasn’t already answered by then,
Also, I have 4 of these that I’m not using if you want them cheap and it’s feasible to ship them to you?
