Meraki MV integration with Homekit?
JohnH4
Has anyone been able to get this to work? I am trying use Homebridge to connect my cameras into Homekit using RTSP, but I am only able to get it to process stills/images. When I try to pull up the live-stream it throws an error.
7 Replies 7
Nick
I haven't but am very interested if you get this to work!
Good luck
JohnH4
I was able to get it to work by disabling audio recording on the cameras. There are a couple of other settings too, let me know if you are unable to get it to work I can try and assist.
Nick_Barron
Hi John,
Excellent news!
So audio has to be disabled? Are you able to post the other settings you needed to change, as it may help others as well.
We can't be the only ones who want this!
JohnH4
I used the ffmpeg plugin "Homebridge Camera FFmpeg" with the following configuration and was able to get it to work. They've recently added some new features that I haven't implemented yet but this is good enough to get started.
"cameras": [
"name": "front-exterior",
"manufacturer": "Cisco Meraki",
"model": "MV72",
"motion": true,
"videoConfig": {
"source": "-rtsp_transport tcp -i rtsp://10.0.3.169:9000/live",
"stillImageSource": "-rtsp_transport tcp -i rtsp://10.0.3.169:9000/live",
"maxStreams": 2,
"maxWidth": 1280,
"maxHeight": 720,
"maxFPS": 20,
"maxBitrate": 3138,
"vcodec": "copy",
"audio": false,
"debug": false
Nick
Thanks John,
Looking forward to trying this
Simeon
Hey, John! 🙂
I can see this post is from 2020 is it still valid? I am trying to RTSP an MV63X but I am getting nowhere.
When you mentioned disabling audio is that both by "audio": false" and the physical switch on the camera?
BR,
Simeon
azchipka
Simeon,
I was just (as in today) able to get this working with the same settings provided above. Note that you MUST disable the audio recording for the camera on the Meraki dashboard as well. Why that's the case is beyond me it shouldn't, matter but as soon as I turned off audio recording on the camera it started working correctly.
