Anyone else experiencing the MV72 focus slowly getting worse over time to the point you have to run another auto-focus.
Not very handy considering the saved footage becomes blurry. Anyone have a fix for this to lock the focus?
Nop, under an eave, picture is perfect when focused.
I wonder if its a camera issue or slight ground movement. Make open a support case they might be able to log into more detail on the camera and see if the focus is adjusting itself somehow.
"Is it possible to use manual focus only, and leave it on that perfect setting?"
This is what I am doing in most cases.
Install camera, run auto-focus, switch the setting to manual focus.
