MV71 Optical Zoom
mkattan
MV71 Optical Zoom
Team,
currently working on configuring some MV71 and the customer is asking for the optical zoom capabilities for the camera lens.
While the MV72 specifies 3x zoom capabilities, could you please advise on the MV71 zoom capabilities as it could not be found in the datasheet.
BrechtSchamp
As @PhilipDAth mentions, the focal length specs say 3-10mm for the MV72 and 3-9mm for the MV71. 3mm x 3 = 9mm so the zoom level of the MV71 is 3x. For the MV72 it's a tad bit more at about 3.3x.
https://meraki.cisco.com/products/security-cameras/mv71#tech-specs
"3 - 10mm vari-focal lens with variable aperture f/1.3 - f/2.5"
BrechtSchamp
mkattan
Thanks a lot team for your response
