MV32 panning problem - turning image upside down while panning
TomMc
I used to able to smoothly pan around the room. Now when I do it the image starts to turn sideways and then upside down as I pan.  Any ideas on how to fix this?
be able to pan around the room with my MV32.
TomMc
Figured out what happened, someone changed the below Mounting setting from 'Ceiling' to 'Wall'.  Looks like a new setting that's in beta.  Changed it back to 'Ceiling' and it was fine.
I suggest you open a support case.
TomMc
Thanks, I may have to. Even old video that I know used to be fine is turning sideways when panning.
BlakeRichardson
Have you updated firmware recently?
Does power cycling the camera help?
Tried a different browser to make sure it's not a dashboard / browser compatibility issue?
TomMc
