MV Camera viewing natively in windows
jetaylor
Hello Everyone,
I've come across many threads about some issues to view footage live from the MV series. I myself have looked into many viewers because the cloud view option locks up sometimes in browser.
I've looked at the following options...
-Local vlan with linux/windows viewing footage on the same V-Lan
-Cross V-lan with Linux/Windows viewing footage.
-RTSP Viewers open source Linux/Windows
-IP Cam viewing software (Generic Software)
-Meraki Vision Portal
-Meraki Video Wall
-VLC with Mosaic view Linux/Windows
-Chrome/Firefox/Safari/Edge/Chromium
And many combinations in between.
I wonder if this would be an option from microsoft and would like to see what everyone's opinion on this would be.
https://blogs.windows.com/windowsdeveloper/2019/10/10/connecting-network-cameras-to-windows-10-devic...
8 Replies 8
What is the problem that you are trying to solve?
Have you tried the Progressive Web App mentioned in this forum post: Progressive Web App and Other Updates for the Vision Portal - The Meraki Community
BlakeRichardson
As @cmr mentioned the new vision portal is a massavie improvement, this is now my go to for viewing MV cameras.
@BlakeRichardson yes it is a huge improvement. But still have the delay with it. I know Meraki will eventually get it working without the latency on the live camera view but we needed a zero latency solution. ill post the full workup i did to resolve my issue below.
@jetaylor  Have you tried a different web browser?
@cmr I have and i still see a huge amount of latency for live viewing.
@jetaylorwhat kind of cameras are you using? The 2nd generation (MVx2) are supporting low-latency HLS (LHLS) with firmware 4.8 or higher. The delay here is normally about 2 seconds instead of 10.
@PhilipDAth I Apologize for the late response on this.
So i was trying to setup a live view on the local subnet for camera viewing. The overall issues is there is a 10 second delay when viewing cameras. Its so odd. But i ended up solving with a RTSP stream from each camera to a web server and i get zero to no latency now what so ever. But even the Meraki Vision Portal has latency on live camera feeds.
