MV Camera Issues - Delay and Video Wall Disconnection
MauroF
I am experiencing two issues with my MV cameras:
  1. There is a 5-second delay in the video feed on my Video Wall. I have a mix of MV63 and MV93 cameras. Is there e solution?
  2. Is there a way it does NOT automatically disconnect the Video Wall every hour?
Thank you for your assistance.
Mauro
@MauroF the delay is often greater, achieving a 5 second delay is actually on the good side.  I know this doesn't help you, but the camera is sending you a recorded stream, it isn't like a traditional IP CCTV system where you can hook into the raw camera feed.
It shouldn't disconnect the video wall every hour.  Try checking the idle timeout configuration.
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Organization_Menu...
Dunky
If you use the Vision Portal and put it into Fullscreen mode that bypasses the global timeout setting.
