Floorplans for Camera-Only Admin Meraki Vision
Mitchell858
We've been trying to get our people setup to view floorplans in the vision portal. If we assign them as Camera-only admins, they can't see floor plans. We've had to assign them as Organization admins but we'd rather not have everyone at that level.
Does anyone know a setting I'm missing to have Camera-only admins be able to view floorplans in the Vision Portal?
Thanks,
Mitch
10 Replies 10
Did you try with the Organization's read-only permission?
Mitchell858
That is our current work around, yes. But I think it's causing all our people to receive Meraki support emails about our networks updates across our different sites and stuff like that. A small problem ,yes, but I figured the it could be fixed for the Camera-Only admin role.
Ryan_Miles
Seems to be a limitation at the moment. And I agree it should be visible as it goes against the point of having camera admin roles. I will check with the Product Team on this.
Mitchell858
derek_b
Any news on this? We're in the same boat as well.
Mitchell858
I've not heard an update. We've got our users as Read Only Organization Admins as a work around.
Mitchell858
Any update on this one? Thanks!
Mitchell858
In the vision portal, I'm finding no way to have a user be able to view floorplans and be restricted to not be able to exports. It's either yes floorplans and yes exports or no to both.
antonyart
You're right, there is currently no way to give a user the ability to view floorplans in the Vision Portal but not allow them to export data. This is a known issue and Meraki is working on a fix.
Mitchell858
