Hey, first time post in this forum!
The connection to one of our cameras was dropping in and out so I went to investigate. The cable looks very kinked so I took the camera, plugged directly into the switch and it is working fine.
I can see that there isn't a lot of room for the cable and therefore it bends significantly in order to plug into the RJ45 port.
I intend to replace the cable - its a 2m cable that runs to cat6a surface mounted box so it shouldn't cause much hassle.
My question is what is the best type of cable with flex protection that you guys would suggest I use in this instance? What should I look for?
Because as you can see the way it was installed clearly wasn't very good.
Must admit there isn't much room.
Thanks in advance for your help
