Power Controls Missing from MT40...
TBHPTL
Really weird situation when accessing MT40 from desktop browser (chrome)...
  • Power controls are present from desktop browser
  • Power controls absent when accessing from a Pixel 6 Pro with Chrome.  The power controls are missing and is replaced by a field labeled "More" when accessing the "More" drop down nothing is present.. This holds true even when the View page as "Desktop site "  box is checked.
Have already tried clearing all browsing history to rule out cached pages.
Anyone else seeing this?
OllieGerrard
Thanks for the catch! We've identified the issue and a fix is in the works. In the meantime, adjusting your chrome zoom level might work - or using the Meraki App would be our preferred option for control from a mobile device.
5 Replies 5
BlakeRichardson
I would say the version of Chrome on the Pixel6 is cutdown. The dashboard isn't really designed to be accessed via browsers on mobile devices, that is what the app is for.
TBHPTL
Been using smartphone browsers with the dashboard for many many years without issue. Also, this has worked previously..
If you turn the phone horizontally, so the screen is wider, does it make any difference?
TBHPTL
Nope
OllieGerrard
