If you deploy a vMX in Azure, and start with the small license, can you then later upgrade to fx. medium license on-the-fly? Or what is needed?
And do you have to change the Azure VM type, if you upgrade from small to medium?
Thanks for any help 🙂
Solved! Go to Solution.
@PhilipDAth is correct here. There are no "upgrade" license SKUs for the vMX sizes. If you currently have a small vMX deployed and would like a large vMX, you will have to purchase a large license and deploy a new instance for the large vMX.
Hi @rasmusan1 , good question. I don’t see any upgrade license which would be a bonus.
if you look at this from a physical perspective I would treat as thus ie you’d need to build a new vMX and swap them over as so and procure a new license for the bigger vMX.
sorry, quite waffly but hope that makes sense
thanks for your reply, however I don't see anything in the deployment guide for Azure, in regards to choosing a specific VM size, depending on the license level - therefore it would make sense to me, if this is just a question of the license applied which limitations is enforced - and thus also possible to upgrade.
Hopefully someone from Meraki will answer this thread, to shed some light on this matter...
@RafaelM , anyone from Meraki able to shed light on this one?
Sorry to have picked on you 😁
You don't really get to choose. The size is specified in the deployment template. You also can't change the size.
To go to a larger VMX would require that a new VMX be deployed. Nothing Meraki can do about that as the Azure configuration for a template is locked by Azure.
Thanks for clarifying - I guess I have to be a bit more forward thinking then 😉
