vIP Setting Issue
kuni
vIP Setting Issue
I have a question about vIP of MX setting.
When I set vIP, It have to put IP address.
In this case, If I set vIP should I get static IP from ISP ?
If I get only dynamic IPs(no static IP) from ISP, How can I set vIP ?
Thank you,
8 Replies 8
your ip range assigned by isp can change?
how many ip' s you have bought from isp?
kuni
Thanks ww for your answer.
I think I can get /29 ip address(Dynamic IPs).
NolanHerring
If you scroll down on this blog post I did a little bit ago, you'll see the section for vIP.
It will require you to have a /29 to be able to use it correctly
https://nolanwifi.com/2018/10/25/you-down-with-l-t-e-yeah-you-know-me-raki/
Nolan Herring | nolanwifi.com
TwitterLinkedIn
kuni
Thank you NolanHerring,
But my question was not /29 bit issue.
I'd like to know that whether it needs static ip or dynamic ip when I set vIP.
There are two types IP(static ip and dynamic ip) in Public IP.
Static IP is more expensive than Dynamic IP.
Thank you,
NolanHerring
If your getting a /29 (which you need for vIP to work), then it is going to be static.
TwitterLinkedIn
kuni
Thank you,
You mean to set vIP, It needs static IP not dynamic IP, right ?
NolanHerring
Correct
Your ISP will give you a /29
Lets pretend they give you 68.10.20.40/29
On your end you'll use those IP addresses however you see fit on your firewalls, but for a vIP it would look like this:
Network Address: 68.10.20.40/29
Usable IP: 68.10.20.41 – vIP
Usable IP: 68.10.20.42 – WAN1 – MX1
Usable IP: 68.10.20.43 – WAN1 – MX2
Usable IP: 68.10.20.44
Usable IP: 68.10.20.45
Usable IP: 68.10.20.46
Broadcast Address: 68.10.20.47
Subnet Mask: 255.255.255.248
TwitterLinkedIn
@kuniyes, you need static IPs (a /29 as @NolanHerring has shown) for the virtual IP setup.
