Is it possible to have the native VLAN 1 (U), and VLANs (T) to trunk on the same interface?
Solved! Go to solution.
Yes
On a port set to trunk, yes.
So I could have a network on the native VLAN 1, which would be untagged right?
They have 2 VLANs (50,100)
Then on port 3 for example on the MX, make it a trunk port, and allow VLAN 1, 50, 100?
Yes.
https://documentation.meraki.com/MX/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Applia...
Ok thank you. Because I'm used to Meraki at my last job. At my new job, they're using a WatchGuard appliance.
And I'm trying to do the same thing on the WatchGuard, but I'm not able to. So just making sure I'm thinking this correctly.
One last question to make sure.
Let's say I have a managed switch with a trunk port 1 for VLANs example 50,100
And I have port 2 on the switch as untagged (U) for VLAN 50
If I connect a non-managed dummy switch to port 2, the devices connected to the dummy switch will get VLAN 50 right?
Am i right?
ok thank you for confirming. So if I can't figure out how to do this on the WatchGuard, I'll have to run another cable.
