untagged and tagged on same interface
tantony-ridge
Is it possible to have the native VLAN 1 (U), and VLANs (T) to trunk on the same interface?
8 Replies 8
On a port set to trunk, yes.
tantony-ridge
So I could have a network on the native VLAN 1, which would be untagged right?
They have 2 VLANs (50,100)
Then on port 3 for example on the MX, make it a trunk port, and allow VLAN 1, 50, 100?
tantony-ridge
Ok thank you.  Because I'm used to Meraki at my last job.  At my new job, they're using a WatchGuard appliance.
And I'm trying to do the same thing on the WatchGuard, but I'm not able to.  So just making sure I'm thinking this correctly.
tantony-ridge
One last question to make sure.
Let's say I have a managed switch with a trunk port 1 for VLANs example 50,100
And I have port 2 on the switch as untagged (U) for VLAN 50
If I connect a non-managed dummy switch to port 2, the devices connected to the dummy switch will get VLAN 50 right?
Yes
tantony-ridge
Am i right?
tantony-ridge
ok thank you for confirming.  So if I can't figure out how to do this on the WatchGuard, I'll have to run another cable.
