"Most affected clients" are invisible
Haikton
Just browsing
Dear colleagues,
I found Trojans at my meraki Security Center, but "Most affected clients" is blank and I cannot identify the source computer which is affected by the Trojans. "Most affected operating systems" OS is blank as well.
Could you please advise how to determine the affected computer?
Thank you in advance.
Hayk
Does it make any difference if you change the period of the security centre, say to two weeks?
Haikton
Just browsing
Hi Philip. I just found the IP in "MX Events" tab, but cannot determine MAC address, its not detected. So, how to locate the device with IP address(without MAC) and block it? Thanks for your response.
Try typing it into Network-Wide/Clients, and see if you can find it that way.  Make sure you have the dashboard configured to display the IP address column.
Haikton
Just browsing
Thanks a lot, Philip. I found the source computer in other way.
Hayk
