can i add 2 ports of meraki to same switch same as we do port channel ?
Solved! Go to solution.
Mx does not support lacp.
You can connect 2 links to a switch, but the switch need to run a kind of stp on the ports
and make sure the mx ports have the same native vlan
if the 2 ports in the switch are configured as port channel we should also allow stp ?
Just separate ports,no channel
And the switch need to talk stp on those ports (mx also does not participate in stp)
