inbound Rules
shadoomere
inbound Rules
Meraki MX
I can't seem to configure IPv 4 inbound source and destination! what are my options then?
the outbound is configurable with the ipv4 but the inbound ?!
i need to allow specific traffic using inbound as there is an implicit deny
2 Replies 2
Use these options
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
In case above doesnt work for you. Inbound rules are enabled when you use no nat.(from the beta page, or contact support)
The inbound firewall is controlled a little bit differently.
The inbound firewall will deny any traffic that does not have a session initiated by a client behind the MX. This allows internal client machines to connect with any resources needed but does not let outside devices initiate connections with inside client machines.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Blocking_Inbound_Traffic_on_MX_Security_...
