Issue With Port Forwarding (MX behind Att Router)
EDIT
Hi Team,
Running into a networking and/or firewall issue where I'm not getting http and https traffic for host on my internal LAN. My setup is as follows:
Previous working topology:
Edge router (att BGW210) <> Virtual switch <> Web Server
New topology not working:
Edge router (att BGW210) <> MX Firewall <> MS Switch <> Virtual switch <> Web Server
On my previous topology, only way it works if I setup port forwarding on the att router to the internal web server. However now that I've implemented the MX firewall and MS switch, can't get port forwarding to work.
On my att router, I now have port forwarding http and https traffic to my MX firewall where I then configured port forwarding on the MX and set my web server as the destination LAN server.  Not sure what step I'm missing buy any guidance would be greatly appreciated.
Note that I tried packet captures on the switch uplink where not seeing any http or https traffic being sent from the MX.
EDIT
Thanks I found the issue and end up being unrelated to the setup. Confirming that my new setup now works.
Do you see the the traffic an the mx wan.
You can also make packet captures  there
EDIT
FRover
Do you recall the solution?
EDIT
I do it was a internal DNS issue in my case. At that time I was using same domain name for both internal/external and although it worked with my Att router originally my assumption is it broke when I migrated to the MX. I've since moved to split brain DNS for my AD and also bought a public IP block so I use public IP on the MX outside interface essentially removing MX from being behind NAT device and allowing NAT at the MX
