We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
i bought already Meraki MS64 with enterprise license ,and contact with Meraki to change license to Advanced license
they asked to confirm with passcode ,please how can i get the passcode
Solved! Go to solution.
Hi @Tamer_MERAKI
@It’s located in the Help section on the dashboard
https://documentation.meraki.com/zGeneral_Administration/Support/Locating_the_Meraki_Customer_Number...
Done .thanks
In the high right corner, to to "MY PROFILE".
There you can find the passcode.
Let me know if this help you.
Regards,
