Object group on mx
Aondio_Carlo
Object group on mx
Good morning, I have to change an old pix 520 with new mx400.
The current pix configuration contains many object groups.
Restoring and maintaining the same configuration on mx400 without these is heavy enough.
I had heard that object groups are in roadmap. Can anyone confirm it?
If is it true that there is hope for us to see them shortly?
Regards
Aondio Carlo
Jollywombat
Been asking for this for quite some time now, Keep hearing thats its on the horizon but no sign of it yet...
Jollywombat
If you can write a script you might be better off writing something to parse the config and configure it directly using the Meraki Dashboard API.
I've now created a script based system that lets you migrate a firewall rule base to Meraki that uses objects, object groups and service groups.
https://community.meraki.com/t5/Dashboard-Administration/Meraki-Object-Groups-You-can-have-them-now/...
