Z3C - Cellular only not working after power loss?
ksumann
Hi everybody,
We have a Z3C here which got its initial configuration through the dashboard.
It was running on cellular only as we did a power cycle by pulling the plug and insert it back again.
The device does not connect anymore with cellular only.
Firmware is 17.10.4
Anyone else seen this?
8 Replies 8
Have you tried a factory reset? Have opened a support case?
That should work.
If you put the SIM into a phone does the data portion still work?
ksumann
A factory reset should not work. The docs say that the initial configuration cannot be done by cellular only.
I didn't open a support case yet because its not reproducible. So i wanted to ask if anyone else has seen that.
tomas209ca
Cellular modem on Z3C can be buggy at times. Which cellular provider are you using? Are you doing static via cellular?
ksumann
Provider is German Telekom using dynamic IP.
Do you have some links about this buggyness?
I suggest you to open a support case.
Melon38110
Have you any news about your issue?
From my side I got quite same behavior.
For month, I used Cellular Fail over without issue, and since several weeks, SM car is not detected ( ICCID no read, nor MSISDN ( Appliance status/Uplinks).
I did a RMA, but it is the sale with new HW!!
ksumann
In firmware 18.208 release notes, there a few points mentioning cellular connectivity
