We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
As said in the title, the change log only show the decimal port number, but not the settings which where changed.
Can someone confirm this?
Can you share an example ?
On what plateform (MX or MS ? )
On the old or newer UI ?
UI shouldn't matter but its the new one. MX Plattform.
This is what the change log looks like
It should contain port type like access or trunk, native vlan, allowed vlan, 802.1x or open....
Can you test with the API ? I'm curious because I have an opened case from early 2023 with a similar behavior however I was able to retrieve the log via the API.
response = dashboard.organizations.getOrganizationConfigurationChanges(ORG_ID, total_pages=1)
does also not contain any port information
On mx access port it shows only the port
On mx trunk it shows only port & native vlan
Yes , very incomplete change log
