Z3 and Internet Speeds
msvt22
We've deployed about 20 Z3s to remote employees over the last few months.  For the most part, things have been working really well.
With a handful of devices, we've noticed a problem where the throughput seems to drop as the work week progresses. A connection will go from 100 Mbit/s + to somewhere around 3-5 Mbit/s.  A device reboot seems to correct the problem.
Has anyone else noticed anything like this?  Any ideas?
TIA.
-Matt
BrandonS
You are seeing this behavior with wireless or wired or both?
Thanks for asking.  I forgot to add this on the problem description.  This is happening with a wired device.
BrandonS
I'm not aware of any 'normal' networking causes for what you describe.  It doesn't sound like packet loss from a duplex mismatch, for example.  And it is obviously not a wireless issue that could have those symptoms. It seems more like a software bug in the Z3 perhaps.  Something like a memory leak or overflowing sessions table over time, etc.  I would open a case with Meraki and they may suggest trying new/beta firmware.
Yeah, I'm thinking this might be something support has to dig into.  I'm hoping this might be a known bug and they can direct me to a FW to try.
I'll post back with the outcome.
Thanks.
