Unfortunately I'm trying to find inbound connections being blocked rather than outbound, so I'm not sure of the source IP. Perhaps I can try to do some digging with destination and see if that turns anything up. I tried checking syslog messages for multiple variants of "l7_firewall" but found nothing. Is this a string that shows up for you in the logs themselves? Are there other keywords that can be searched for that appear in these rejections? Edit: For example, when there is an IDS event, the syslog contains the string "security_event ids_alerted". I couldn't find any documentation for what logs are generated when a GeoIP rule gets triggered. Near as I can tell, this may not even be working. For example, I just saw an IDS alert for a command injection attempt from source IP in China, which should be getting blocked by the GeoIP rule.
