- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Why are Vlan objects in L3 outbound showing in HA setup as an option
Hi All,
today a colleague noticed that when creating MX L3 outbound FW rules, the Vlan object option was unavailable to select. after some digging between networks where it is available the only differences I could find is related to Single Unit (standalone MX setup, where the option is visible and configurable) vs a MX HA setup ( 2MX's, option not visible)
I also tried to set it via the API, but this gives errors on the networks with HA setup, where with single MX setup it works fine.
Anyone else noticed?
Is this a bug or what could be the reason why in HA setup the MX FW L3 are not capable of using Vlan objects? (me and my colleague where unable to think of any reason)
As it is not a dealbreaker yet, I didn't raise a ticket for this one. (yet)
Hope someone could point me in right direction.
with regards Yoeri
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @YoeriOppelaar1,
@ww is correct - IPv6 LAN capabilities are a requirement for VLAN Objects and thus not supported on HA setups at this time, as MX HA pairs do not currently support IPv6.
This information is officially documented in the VLAN objects article below:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Network_Objects_Configuration_Guide...
Best,
Feli
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It has something to do with ipv6 support.
And Warm spare doesnt support ipv6
It would be great if the vlan in the firewall would be available in both modes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The moment you have IPv6 support on you get the VLAN objects.
The reasoning is that VLAN objects match both IPv4 and all the different IPv6 addresses a certain host has in a certain VLAN.
I really like this dynamic object and would love it if Meraki would just enable this at all times regardless of the IPv6 support state.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That is actually awesome.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Best,
Feli
