Where can I find if a IP or network is being blocked by Layer 3 MX Firewall rules?
bayet
Is there a way to find which Layer 3 firewall rules blocking network traffic on the MX firewall.
Thanks,
Bayet
2 Replies 2
AjitKumar
Hi Bayet
I believe we need Syslog to capture such events.
Dashboard may not display these events as of now.
Regards
Ajit
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Adam
Security Appliance>Firewall, it will show hits in the rightmost column but won't show you specifically what as blocked.
