Warmspare using lan public pool
Vishal07
Hi All,
Can we configure warmspare for Meraki MX using Lan public ip pool. Please find below details.
Wan ip pool- 1.1.1.1/30
 Lan ip pool- 2.2.2.1/29
Do you want to use these listed IPs?
No, it is not possible.
The ideal is to use at least a /29 provided by your operator. If this is not available, you can use a private LAN address.
See the documentation.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Vishal07
We have lan public ip pool that's routed on wan ip pool. Here mux having one of the ip assigned from wan ip pool. So can i use lan public ip pool to assign each meraki mx uplink ip and one vip
Mloraditch
Presuming you are trying to avoid putting a router in place, technically I can imagine a backwards way to make this work. This would not be something you’d want to do. Youd have to rely on the primary firewall to route the block which would make the secondary dependent on it which makes actual failover not possible.
Most ISPs (at least in the US) will hand off a /29 directly these days and that would be the easiest way to get failover working without having to buy or rent a router
Vishal07
