Warmspare for 2DCs physically separated
kima25
For my SD-WAN project, the client has two physically separated data centers connected via a Level 2 link. Can I place an MX in each data center and use Warm Spare with a single license for both MX units? If so, what are the potential drawbacks of this solution?
Thank you for your help!
You can, but if the single L2 link fails, both will go master/master, so there is little redundancy.  You might have to manually intervene during a failure and turn off one of the MXs (which is also an acceptable DR method if it is part of your plan).
You could consider getting a pair of L2 circuits (ideally channelled together) for redundancy.
2 Replies 2
Inderdeep
Only one license is required for an HA pair. The warm spare unit does not require a separate license. Alerts for Warm spare failover can be configured on the Alerts and Administration page.“
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Do I need duplicate licenses to cover my security appliance in a warm spare configuration?
A: No, if two security appliances are in a warm spare/HA configuration licensing is only required for one of the two devices. The only additional cost of a warm spare configuration is the redundant hardware.“
https://documentation.meraki.com/zGeneral_Administration/Licensing/Meraki_Licensing_FAQs
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
