VPN Client Meraki MX - Laptop W10 Mistake
Carlos1
Hi team, I'm reaching out for your expertise. I'm having an issue with the Meraki VPN client.
We have two MX64 <-MS <- MR connected to Windows 10 laptops. We configured it according to Meraki's guides, but it's displaying the following message:
The strange thing is that we've also configured it on macOS, and it works perfectly; the connection is successful.
I see some posts indicating that it's due to a Windows update, but those posts are three years old 2022-2023. I don't know if anyone is still experiencing this problem in 2026.
Regards
18 Replies 18
KarstenI
First: Try the script from @PhilipDAth
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
And even better, get some Cisco Secure Client Licenses and use AnyConnect. That is much better and more powerful.
Carlos1
I tried using the provided script, but the problem persists.
I configured it with AnyConnect, but the problem remains.
what is the error code?
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Troubleshooting_and_Support/Troubleshooting/Trou...
Carlos1
This is Error in log dashboard Meraki with AnyConnect
You need to check the Windows logs in the Windows Event Viewer.
Take a look at the link I sent you.
These logs are related to AnyConnect, and from what I see, you're using the native Windows client with L2TP. Therefore, this log doesn't make any sense.
Carlos1
this error 789
Adapter VPN-Test (spanish) - is correct?
Change the option highlighted in red to not require a cryptography, set as optional.
Carlos1
IKE and AuthIP IPsec keying modules disabled
This might occur if third-party VPN software has been installed and disables the IKEEXT service. To reenable the service:
  1. On the affected device, press the Windows key and type Control Panel
  2. From the search results, click on Control Panel
  3. Navigate to Administrative Tools > Services
  4.  Find the service named "IKE and AuthIP IPsec Keying Modules" and double-click to open
  5. Select Automatic from the Startup type drop-down menu
 If the service automatically reverts to Disabled, or fails to start, remove the third-party VPN software.
Try connecting using "rasphone.exe".  It displays better errors on Windows.
Take any error code and then look it up here:
After using the script, try rebooting.  It sets a couple of registry entries to make the Windows client VPN more reliable.
Also, try connecting from a different Internet connection.
Just one question: are you performing this test on the same network where the MX is installed, or on a remote network (like in your home, for example)?
If you're on the local network where the MX is installed, this won't work.
Carlos1
I am doing the tests at another location
Carlos1
The IPsec service isn't showing up for me =O
How do I make those IPsec services appear?
I don't speak Spanish, but considering it's similar to Portuguese, it should be listed under the letter M.
Carlos1
If I check, I think I've already located it.
Registry Adjustment (for NAT network)
If your client or server is behind a router with NAT:
Open the Registry Editor (regedit).
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent.
Create a DWORD AssumeUDPEncapsulationContextOnSendRule and set the value to 2.
Restart the machine.
Carlos1
Hi @alemabrahao
I performed the indicated tests but the problem persists in W10. I tried configuring it with Anyconnect but the problem continues. I did it with Mac OS using Anyconnect and it didn't work.
