MX to Azure site-site VPN using IKEv2
IsayahCox
We're looking into setting up a VPN from our Meraki MX device to our Azure environment, however we have seen that some issues may arise when it comes to using IKEv2. does anyone have some documentation on this kind of VPN being setup?
Thank you!
RWelch
Configuring Site to Site VPN tunnels to Azure VPN Gateway
I would like to point you that a VMX-S (VMX Small) is relatively cheap, and AutoVPN makes things simple.
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Install_and_Get_Started/Installation_Guides/vMX_...
AlexP
Routed tunnel have resolved a lot of the more commons issues we've seen with Azure, for whatever it's worth. They take a bit more effort to set up since you either need a way to monitor tunnel health, or set up BGP, but the actual parameters to set up the tunnel are far simpler.
