VPN CLIENTs moving to other organization
MauroF
Ive got 200 clients using the VPN SSL in the current organization. If i migrate the firewall in a new organization i lose all the clients' passwords. This is a a problem.
Im trying to find a solution for it. Is there any way via API to duplicate all the clients to the new organization before migration or at least to decrypt the passwords in order to reconfigure them all in the new organization?
Any idea?
MF
ConnorL
Meraki Employee All-Star
You'd likely want to look at using an external solution if you have a large number of clients, such as RADIUS, Active Directory or an external SSO provider.
I am not aware of any way to move these users over. If an organisation is split (i.e. split 1 or more networks out into their own organisation) Meraki Support can copy over organisation admins, but there's no way for us to move non-admin users (such as splash / meraki auth)
5 Replies 5
Meraki does not support configuring Client VPN via API.
You will have to add the new organization manually.
MauroF
Actually Meraki told me they can but onlx for administators, not for Guest(clients) but i wanted to hear some other opinions.
Yes their statement is correct, so for guest users you will have to add them manually.
ConnorL
No.
