How to disable older TLS versions in the Meraki MX security appliances?
rhamersley
Meraki security appliance does not have an “SSL Decryption” setting in the dashboard.  How can you enforce higher security standards to block older TLS versions.   Ideally we would like to block all outdated TLS versions.   I do believe Meraki does not provide a direct way to specify TLS versions in Layer 7 rules.   Would like to get insight to see how this is possible.
Thank you!!
With MX I believe you won't be able to do anything, you will probably need another solution or even another firewall.
To add to @alemabrahao answer (which is correct), Cisco would recommend the use of Cisco Umbrella - which only supports TLSv1.2 clients.
Both Meraki MX and MR devices have native Umbrella integration options.
https://documentation.meraki.com/MX/Meraki_Umbrella_SDWAN_Connector/Deployment_Guide
jfigueroa
This is talking about 802.1x specifically.
