Unable to see all my clients on MX100
I recently installed a MX100 on my network. The LAN portion of the MX sits on a VLAN2 and my users/clients are in another VLAN3 and there is a core switch that acts as the default gateway for the clients.
When I go to all network-wide\clients, all I see is the traffic coming from the switch, meaning all I see is the switch itself but I do not see any individual clients.
How can I change the configuration to be able to see each device that uses the MX coming from the Switch from different VLANs?
Thank you
Ricardo U
Accepted Solutions
Re: Unable to see all my clients on MX100
Under the Addressing & VLANs page you're going to want to change the "Client Tracking" setting to IP.
3 REPLIES 3
assuming the Core Switch is the dhcp server and behind your MX, thats why you won´t see the Clients and only the traffic from the Switch.
Thanks guys, that worked nicely.
