USB and Integrated cellular modem are as primary in MX67C?
DAIDAI
I'd like to use both USB(cellular) and LTE modem as primary active link at a time in MX67C.
I don't use cable WAN.
Can I do this?  or is one side only?
You can use either the built in LTE modem or an external USB LTE modem - but not both at the same time.  As soon as you plug in a USB LTE modem it disables the internal LTE modem.
To use both the external LTE device would need to provide an Ethernet presentation.
2 Replies 2
Cmiller
The best work around for this (until Meraki enables dual LTE capability which I keep dreaming about) would be to purchase a separate LTE modem like pepwave offers https://www.peplink.com/products/max-cellular-router/multi-cellular/ and use it to plug into the WAN port on your MX.
