Top 100 (or more Sites)
SynapticCleft
In an MX400, is it possible using Reports or the API to output the top 100 or more websites visited?  I have not found a way to do it yet. Ideas anyone?
Adam
I'm not sure if there is more available via the API, but in the dashboard the closest I know of is going to Network Wide>Traffic Analytics then you can sort the result by clients column.  Note:  This includes application data as well so it won't just be websites but I figure it would be equally interesting.
+1 to @Adam. Also make sure you have enabled the collection of hostnames under Network Wide/General.
BlakeRichardson
This is one area that I feel needs massive room for improvement. My environment requires me to be able to see in detail where users have been.
The web reporting is lacking and is well behind other vendors. I do hope they improve this in the future.
