I have a problem, I am implementing a mx-100 with static routes with different next hop according to the destination. The fact is that when you activate the routes in the table of a next hop the others are deactivated
I have already solved the problem, for some reason, the Meraki did not support the configuration of 2 ports in different vlans. What I did was to truncate the 2 vlans in a single port, with this the routing problem was solved.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
