- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Static Routes on Meraki MX64 (Multiple Routes?)
I was wondering if we are able to add multiple (more than one) static routes on Cisco Meraki MX64.
It seems to have a limitation for only one static route under "Security & SD-WAN --> Configure --> Addressing & VLANs".
When i am trying to add more than one route here, i get only the option to update the already existing route (attached screenshot).
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This seems to be strange.
I tried doing this again on my PC. I found no issues.
How about making sure about the following.
1. Create 1 Route at a Time. Save Changes. Refresh the page and try adding new Route.
2. Make sure while creating new route no check boxes are selected under Static Route.
3. Try using another browser / incognito mode of the browser.
Hope this helps.
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Certainly you can add multiple static route. The UI (User Interface) on the dashboard projects as if you are updating the Routing Table.
Screenshot attached for reference.
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dear Ajit,
I have tried to add an extra static route and as soon as i pressed "Update" the new route replaces the old one instead of adding it as a new one. I don't get if i am doing something wrong (although it seems to be as simple as ever), or it is just some kind of bug or something like that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hope this helps.
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is the 192.168.25.1 an IP address of a neighboring (connected) L3 device on your MX64 or is it assigned local on a port of your MX? I suppose that this IP belongs to a connected L3 device. Correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In my case 192.168.25.1 is the IP address of MX.
192.168.25.0/24 Subnet is a VLAN created on MX for LAN. (I was simply trying to replicate your case on the same box)
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have tried from a different browser and it worked.
Never passed my mind to try this, but i didn't expect that i should any issues like that.
Thank you very much for your time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Always use chrome as Merakis uses Chrome for testing. As I heard on a meraki event.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What browser are you using? I bet it was Firefox. I login with both Firefox and Chrome.
some pages have problem with Firefox and others with Chrome.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I was using Google Chrome.
Tried and logged in from Firefox and it worked.
Afterwords when i tried again from Google Chrome, i was able to make changes from Chrome as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just tried it, getting the following errormessage:
There were errors in saving this configuration:
- The static LAN route "Test" has an invalid next hop IP. The IP address 10.0.1.1 is not on a configured subnet.
- The static LAN route "Test2" has an invalid next hop IP. The IP address 10.0.2.1 is not on a configured subnet.
So, seems like you have to add the subnets for the static routes first. In general, there was no problem in configureing, more than one static route.
