Hi there, I have two different vlans on a MX64 and would like to split the bandwidth between the two vlans.
Solved! Go to Solution.
You can create a Group policy configuring traffic shaping and set this group policy on SVI. Check the documentation:
They can both use the internet.
You can limit the speed for each user.
You cant set a limit for each vlan
How do you set a limit for each vlan?
If your question is per user in a vlan then what @alemabrahao posted
If your question is to limit the vlan itself. Then, You cant. The bw limits are for users.
Esas dos Vlan estan configuradas en el mismo MX??
Si es asi, podrias crear dos diferentes politicas de grupo y asi poder limitar el ancho de banda para cada una de ellas!!
Recuerda que una vez creadas las politicas de grupo debe de asiganarse dentro de la Vlan en Adressing & VLAN
