Split Internet Speed between two vlans on MX64
MWRD
Hi there, I have two different vlans on a MX64 and would like to split the bandwidth between the two vlans.
You can create a Group policy configuring traffic shaping and set this group policy on SVI. Check the documentation:
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
6 Replies 6
They can both use the internet.
You can limit the speed for each user.
You cant set a limit for each vlan
MWRD
How do you set a limit for each vlan?
If your question is per user in a vlan then what @alemabrahao posted
If your question is to limit the vlan itself. Then, You cant. The bw limits are for users.
Here you can find more informations:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Traffic_and_Bandwidth_Shaping
IvanMA23
Esas dos Vlan estan configuradas en el mismo MX??
Si es asi, podrias crear dos diferentes politicas de grupo y asi poder limitar el ancho de banda para cada una de ellas!!
Recuerda que una vez creadas las politicas de grupo debe de asiganarse dentro de la Vlan en Adressing & VLAN
