Site to site VPN to non-meraki and tags
pwb
Hi, we have multiple Meraki devices (MX64) (Networks) under our Oganization, this networks are different customers and shouldnt have any connection to each other. Some of this networks should have site to site VPN to other non-meraki devices, but the networks (MX64) shouldnt have connection to each other. I have tried to use tags on the networks and in the non-meraki VPN peers. But as soon as i add a tag then the VPN dont work from the MX64 to the non-meraki, but it works the other way. Since the other VPN box is a non-meraki i have to use hub and not spoke? Any info on how to setup this?
BrandonS
"..networks are different customers and shouldnt have any connection to each other. .."
"..but the networks (MX64) shouldnt have connection to each other."
If that is the case why are they all in the same organization?  It seems all your customers should be their own org: https://meraki.cisco.com/blog/tag/msp/
5 Replies 5
BrandonS
pwb
Yes, i think that would have been the best thing. But it was like this when i should setup the VPN. But is it easy to move the MX64 to a new organization?
Mr_IT_Guy
@pwb, if you call support, they can move the MX64 into a new organization and retain all the current settings.
BrandonS
I would ask support.  It is technically possible, but it is also policy that licenses are not transferrable between organizations.  You may have a unique case though and if you ask nicely, support could theoretically help you split the license you have between multiple new organizations.
JasonCampbell
Meraki Support will move licenses to other orgs without issue, I have done so multiple times in the past.
