Site to Site with non meraki
PatrikStar
Can I build like this?
I have four sites with MX and one site with Non Meraki FW.
One site is Hub.
Three sites is Spoke.
I want the Hub-MX to have an S2S VPN to the Non Meraki Site/FW.
The Spokes can access the Non Meraki Site through the Hub.
All traffic that is going to my networks subnets should go through the VPN.
Everything else should go through each sites "normal" internet.
Is it possible?
If you could place another device at the hub site that build the tunnel to the non meraki fw. And then point static routes from the hub to that device it would work
4 REPLIES 4
No, all spokes  also need a tunnel to the non meraki fw
I was afraid of that. 😞
Thank you for the answer.
Great answer. 🙂
That gave me some hope.
Thank you again.
