Site-to-Site Vpn is disconnected
ElGamaci
Evening,
I'm facing a disconnected site-to-site vpn between two meraki Mxs, VPN Registry is Connected , NAT type is Friendly  and session is Encrypted, however i get red status on vpn, any advice.
ElGamaci
I just opend a case with support team, and support alert me to the packet loss, as i found high packet loss in the uplink when the vpn connection is down, and when there is no packet loss, everything working fine.
thanks for your reply
5 Replies 5
Ryan_Miles
Meraki Employee All-Star
Did it work previously? If so the first thing I'd do is reboot each MX.
ElGamaci
Yes It works before,
In Fact, the connection is flapping every few hours,
and every time i tried with reboot each mxs and their internet sources, with no luck
Ryan_Miles
Have you opened a Support case? Sounds like this requires some troubleshooting by Support.
ElGamaci
mweber560
You should also check your ISP(s). They may have an issue in one of their cores that maybe causing this as well. If you have the 16.6 version of the firmware installed with Meraki Insight you also now have access to the thousandeyes outage map straight from the dashboard.
Matthew R Weber, CMSS, CCNP
