I have 2 sites. Site A and Site B with MX250s. Site to site tunnel is configured between these 2 sites. Site A also have site to site tunnel configured to AWS tunnel. Site B don't have AWS tunnel. On site A, we have client VPN.
If someone on Site B want to access AWS stuff, can they connect to Site A's client VPN ?
Solved! Go to solution.
They could. The Client VPN flow will be over the internet and not in the S2S VPN. Client VPN on Site B -> ( Internet ) Site A -> AWS.
In that case having or not the S2S between Site A and Site B is irrelevant
That would be one way to do it.
I just tried Client VPN and site to site tunnel enabled and I am not able to connect client VPN from Site B to site A. As soon as I disable site to site tunnel , client VPN works.
You are probably in full tunnel mode. Your Client VPN flow is going thru your VPN tunnel and not over the internet.
@RaphaelL What do you mean by full tunnel mode? I don't have client VPN subnet and subnet which client is connected to at site B is in site to site tunnel.
I only have site to site configured for management VLAN only.
I think what's happening here is when client VPN requests from Site B to Site A, Site A thinks this is from S2S and responding on S2S. I don't see any phase 2 traffic on pcap
This is what I am trying to achieve. Just did diagram in case there is confusion.
S2S tunnel is only between mgmt vlan 192.168.23.0/24 and 10.0.23.0/24
UserVLAN 172.10.0.0/16 is not included in s2s.
Hi ,
"As soon as I disable site to site tunnel , client VPN works" this was a good indicator that you were in full tunnel and lan trafic from 172.10.0.0/16 is routed through the S2S.
If thats not the case , do you have a firewall rule to allow the outbound trafic ( on Site B )
@RaphaelL This is what I have in tunnel
I don't have firewall allow outbound rule traffic on site B.
Are you not using auto-vpn between your 2 Meraki products ? I'm so confused...
Sorry I got wrong screenshot. Ignore that SS.
@RaphaelL I think I found solution. There was some old configuration it was blocking it. It's working now. You're absolutely right, S2S shouldn't affect client VPN. Thank you!!
