Site to Site VPN's in Different Networks
DanielBHSNIT
In my dashboard I have eight separate networks, all different geographic locations, all with MX64's.  I want to set up site-to-site VPN's on these but when I go to enable them, nothing shows up under Hub or Spoke.  Is there a way to do this or do I need to move everything under one network?  I'd prefer not to move anything right now.
You need to make at least 1 device a hub. Then go to another network and make a spoke and select that hub
You could also make all networks hub if you want a full mesh setup.
If you networks are in different organizations then you cant use autovpn, but you could use 3rd party vpn
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
https://documentation.meraki.com/MX/Site-to-site_VPN/Configuring_Site-to-site_VPN_between_MX_Applian...
3 REPLIES 3
DanielBHSNIT
I guess I'm not familiar enough (yet) about making 1 device a hub or making all networks a hub.  The networks are in the same organization just different networks.
Follow the links that @ww gave you.  They include step by step instructions.
