- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Setup Pitney Bowes DA70S Addressing Printer using static IP port 5100
Hi all,
I was stuck in setup printer pitney bowes DA70S in my office.
My office use MX80 and switch MS220.
I have configure the printer with static IP 10.xx.xx.25, port 5100, gateway 10.xx.xx.01, submask 255.xxx.xxx.xxx
This printer connect to our LAN network
I can ping to those IP from my laptop through wireless and network, but I can do print on those printer.
Other printers like HP no issue, just setup static IP then on client pc/laptop just setup the assign static IP then select the correct printer driver after that all done and worked fine. Don't need to touch MX80 and MS220.
But for this Pitney printer, I was stuck for many days wasted just to find the correct configuration and solution.
I worried about the port 5100 that assigned from the Pitney printer.
Please help and much appreciate for any suggestion or solution from you all.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am not sure if this is a networking issue.
One idea is to "Whitelist" the printer and try to printing.
(Network-wide->Clients->[Select the printer]->Click on "Policy" Drop Down->Select Whitelisted)
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I can ping to those IP from my laptop through wireless and network, but I can't do print on those printer.
*correct my typo missing 't
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You'll need to contact the people you got the printer from for support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Philip,
We got it from or UK office and the person already resigned from work few months ago.
We couldn't contacted him anymore.
I will try to add it as white-list as advise from AjitKumar
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Finally I done to setup it and thanks a lot for AJitKumar after I added White List to those printer.
Just re-installed the driver again with complete drivers then add the printer with default custom settings,
after that those Pitney Bowes DA70S printer working properly 🙂
