As already mentioned, IP does not work the way you want to have it. But there is a workaround that is not very elegant and is some initial work, but could improve the situation if there is no budget to increase the bandwidth:
1) Try to find out which users are needing a better uplink to the internet and which users are fine with a low uplink and a high downlink.
2) make sure that these users have fixed IPs or DHCP reservations
3) configure Flow-preferences (under Security & SD-WAN -> SD-WAN & Traffic Shaping) to steer the users to the optimal uplink.
