Security Center - Top Sources of Threats - Whitelist vs Blacklist
Austin_Campbell
I have noticed that when applying a country blacklist in firewall rules that in security center the map shows the blocked countries in red as shown in my picture below. However, when you apply a whitelist to a few specific countries it does not identify the whitelisted countries or show the countries that are not on the whitelisted as blocked. The entire map is just grey. Is this something that can be looked into? Just a small visual feature that would be nice to see. Thanks.
5 REPLIES 5
Inderdeep
@Austin_Campbell : So you think it should be colored like Green for Whitelisting ?.. Just a view 🙂
Regards/Inder
www.thenetworkdna.com
Yes, exactly something like that.
Use the “Give your Feedback” button on the bottom of the page and do just that.
@Austin_Campbell : show your requirement with your feedback button, Some one will surely come back to you !
Regards/Inder
Just did it. Thanks!
